December 4, 2018, 09:47 |
in-pipe turbine meshing
Farzan
Hello
My geometry which I want to apply mesh on it is an in-pipe turbine. There are two bodies: a turbine and a pipe. The blades are surrounded by a sphere that is subtracted from the pipe which indicates that different analysis should be applied on inside and outside of this sphere (figure 1). My meshing strategy implemented as follows: 1- An edge sizing which it’s type is element size (0.005 m) for the intersection of the blades and discs. 2- two edge sizing that their number of divisions is 20. One of them is applied for the blades’ edges and the other one is applied for the disc’s edges. 3- an inflation for the surface of the sphere. 4- A face meshing for the pipe. 5- a face sizing for the inner and outer pipe surfaces and inlet and outlet regions. 6- A face sizing for the sphere. 7- an inflation for the pipe’s walls (figure 6). At last, the challenges are: 1- the inner volume of the sphere doesn’t mesh for small edge sizing (figure 4). 2- the maximum skewness is 1 (figure 7), the low-quality elements are placed at the location of the intersection of the discs and the blades (figure 5). 3- I can’t apply face meshing on discs. I will be so thankful if you help me. Should I change my meshing strategy? |
ansys workbench, in-pipe turbine, maximum skewness, meshing strategy |
AutoGrid - Meshing wind turbine blade | Ko_Shine | Fidelity CFD | 4 | December 20, 2018 11:27 |
[ICEM] tidal turbine meshing in ICEM inside a water channel | eeLio | ANSYS Meshing & Geometry | 0 | January 11, 2018 09:53 |
[Workbench] Meshing for perforated pipe buried in porous zone | Tanjina | ANSYS Meshing & Geometry | 0 | September 24, 2014 09:41 |
[Other] separated pipe meshing | tomokus | OpenFOAM Meshing & Mesh Conversion | 0 | May 5, 2014 08:38 |
[GAMBIT] Meshing a pipe | vedravi | ANSYS Meshing & Geometry | 1 | March 25, 2010 13:19 |
