[Other] how to get complete turbo by BladeGen/TurboGrid |
April 19, 2012, 08:29 |
Hai Yu
Rep Power: 17 |
Hallo, dear all
I am now simulating a pump with BladeGen/TurboGrid and CFX. I found that, BladeGen/TurboGrid can only make Geo and mesh for one Blade, but not the complete turbo. Instead of only one blade, I want the mesh for the whole turbo, is it possible to do this in BladeGen or TurboGrid? Or otherwise, the only possibility is to copy the mesh in CFX pre? Thank you for hints, Best Regards, |
April 19, 2012, 11:08 |
Hai Yu
Rep Power: 17 |
April 20, 2012, 08:42 |
Hai Yu
Rep Power: 17 |
May 9, 2013, 06:02 |
Sajin
Rep Power: 13 |
Sir,
If I mesh a single stator rotor in turbogrid and the entire volute in ICEM, import the stator rotor mesh to CFX PRE and apply the entire passage so that it become 360 degree.Now can I add the volute mesh from ICEM on to it with CGI and will it work? |
March 16, 2016, 02:05 |
#8 | |
pasa
April 26, 2016, 03:33 |
#10 |
ngoc tran bao
Rep Power: 10 |
Sir, I am carrying out a pump simulation. I have a full geometry of the pump and I can not initialize it in CFX-post. There is always an error like this: "Please verify that the rotation axis and turbo regions are set correctly" even when I set them carefully in previous steps. I also try to initialize a periodic example model and it work well. So, I am wondering if Turbo Tab only work with periodic geometries, not full geometries. As a result, I can not get turbo chart and report with a simulation of a full pump geometry. If I am wrong, can you give me some points? Thank you in advance.
December 6, 2018, 07:32 |
#11 | |
jiaji lu
Rep Power: 8 |
how to get complete streamline(pathline) in pump? | yuhai | CFX | 0 | March 11, 2012 08:33 |
[GAMBIT] problems with gambit tools turbo | qxtxdy | ANSYS Meshing & Geometry | 0 | October 15, 2010 22:33 |
gambit turbo file format | ventoneac_diana | Main CFD Forum | 0 | April 29, 2010 12:02 |
Gambit turbo problem. | sujan.dasmahapatra | FLUENT | 0 | December 20, 2009 05:21 |
Turbo noise macro | Barri | CFX | 0 | May 21, 2008 09:26 |
