[ANSYS Meshing] Problem in generating mesh topology |
January 4, 2019, 04:20 |
Alice
Rep Power: 7 |
hello,
I want to calculate an impeller with one main blade and three splitter blades. I am trying to generate the mesh of the impeller with TurboGrid. However, the automatic mode could not generate the mesh topology. And the grid used manual mode was too messy to adjust. Is there any other way to generate the grid? Or use other software? Thanks Alice |
[ANSYS Meshing] Problem generating mesh (Cornell University tutorial) | lape95 | ANSYS Meshing & Geometry | 1 | June 5, 2018 08:34 |
Bad elements after generating unstructured volume mesh | max_beetle | Pointwise & Gridgen | 0 | October 24, 2017 01:52 |
Problem in generating mesh file for fluent | saeedr | Mesh Generation & Pre-Processing | 0 | December 20, 2014 11:13 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
