[ICEM] 2D Boundary Layer Edges
Old   March 8, 2019, 11:49
Default 2D Boundary Layer Edges
eknight is on a distinguished road
I'm making a 2D geometry that needs a fine boundary layer around certain edges and I've been having a lot of issues making the boundary layer collapse into the walls without needing to manually change the spacing.
I need to have a different gradient within the actual edge, so ideally I would be able to control the edge mesh and the boundary layer separately. Right now I am using prism growth on the curve, but it doesn't continue to the edges. I also checked Blayer 2d in the "Advanced Prism Meshing Parameters" but this didn't seem to change anything.
Any help would be much appreciated! Thank you in advanced!
eknight is offline   Reply With Quote
boundary layer, two dimensional model
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 15:15
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
