[ANSYS Meshing] Build grid: Aborted due to critical error |
January 31, 2012, 11:54 |
Krishna_Aero
Hi All,
I am having issues with importing my 2D mesh into Fluent. The geometry has a simple conical nozzle extending into a test section that has a truncated conical specimen placed inside. Its a PATRAN file created using ESI's CFD-GEOM. I did check my grid 100 times for flaws and found none. I tried different domain configurations to make this work but that was just a waste of time. When I break my grid into 2 different pieces i.e., nozzle and test section, I am able to import them successfully. But when it comes to the whole setup, the error message " Build grid: Aborted due to critical error" pops up and the the function window says " Cell centroid is xc: "(some value)" and yc : "(some value)" WARNING: no face with given nodes. Thread 1, cell 22109 Clearing partially read grid. Error: Build grid: Aborted due to critical error Error object: #f " Please suggest some good techniques to make this work. |
January 31, 2012, 12:49 |
Ali
Rep Power: 16 |
A number of reasons can produce this error, don't know exactly which one?
Regards Hybrid |
February 1, 2012, 21:41 |
Krishna_Aero
@Far: It is a 2D mesh and I trying to import it into ANSYS 13,0.
@Ali: Thanks for the suggestions. I did try importing it in different formats but that did nit work either. May be I just need to fiddle around the mesh till it gets imported. Is there any other reason that you can think of ? |
February 7, 2012, 11:47 |
Ali
Rep Power: 16 |
try to load ur file in tgrid or icem!
August 2, 2013, 14:15 |
#7 | |
Cagri Metin
Rep Power: 12 |
I have same problem you can see problem curve when uncheck shells under mesh and associate that curve , on the other hand if you working sharp tail edge and you should create a curve this is important which is associated curve of airfoil |
June 14, 2017, 05:03 |
negative volume cells
Hamed
Rep Power: 12 |
In my case (ICEM CFD block mesh), I had plenty of negative volume cells because of inverted blocks.
Then I fixed inverted blocks by >> Blocking/BlockChecks/method/Fix Inverted Blocks, and it solved the problem. |
July 1, 2018, 15:38 |
#9 |
mehran mohammadi
Rep Power: 9 |
thank you, your solution worked very well
November 19, 2018, 20:34 |
#10 |
hector
March 13, 2019, 02:15 |
#11 |
NAMRATHA
hi, i fixed those inverted blocks too. even then it shows the same error. so,what else would be the problem?
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 07:12 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
