[ICEM] How to change blocking around the mesh with change in design parameters? |
June 11, 2019, 16:39 |
Anup Jain
Rep Power: 7 |
I am trying to run a optimization problem. My optimization flow is Design Modeler --> ICEM CFD --> Fluent --> Design Exploration. When I change the parameters in the Design Exploration the Geometry changes. With this change in geometry the mesh created in ICEM CFD also changes . However, it seems that the blocking created during the first iteration remains the sane. As result when I change the geometric parameters, due the same blocking and changed mesh I have overlapping edges. Can anyone tell how to change the blocking with the change in Geometry. Or is there some other way that I cam create mesh around the geometry without creating blocking and for the rest of the domain I have blocking. I have attached the snapshot. Image 1 is the geometry. Image 2 is the blocking and image is 3 is if we can do something like this. Thanks, |
design explorer, fluent, icem 2d blocking |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
Mesh Morpher -Deformation, How to change Parameters Values through UDF? | alasz | FLUENT | 0 | December 21, 2018 10:01 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Mesh sensitivity when using phase change models | BKaus | STAR-CCM+ | 0 | February 28, 2012 20:51 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
