[ANSYS Meshing] 3D rotating wind turbine using overset mesh
Old   September 10, 2019, 23:18
Default 3D rotating wind turbine using overset mesh
Anon
Paku is on a distinguished road
Hi, im currently using Ansys v18.2 and ansys design modeller for modelling
I try using overset mesh for wind turbine simulation in 3D, so far my simulation still failing
I have done 2D wind turbine simulation using overset mesh, and it work but not for 3D
For 3D moving object in straight line simulation using overset mesh also work just fine
So i wondering if anyone out there successfully use 3D simulation for rotating object using overset mesh in fluent?
Yeah i know you can use sliding mesh etc but i want to know if overset mesh work
Paku is offline   Reply With Quote
[Other] 3D Mesh of a wind turbine blade. Which tool to use? WhiteW OpenFOAM Meshing & Mesh Conversion 0 May 13, 2016 04:11
Wind Turbine, polyhedral mesh Nabuchadresar STAR-CCM+ 2 September 21, 2015 07:43
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
