[ICEM] Trying to create high aspect ratio tetrahedral elements. |
February 4, 2020, 19:41 |
I am trying to mesh a geometry that includes both spider-wide like complex geometries as well as simple geometries. Essentially, my problem is a long pipe with a localized flow obstruction.
I require a purely hexahedral mesh. The current strategy is to first use an unstructured tetrahedral mesh and then convert it to a purely hexahedral mesh. This allows for the rapid generation of hexahedral meshes for complex geometries. The main problem however is that this generates too many elements. In regions of simpler geometry, it would be allowable to use very high aspect ratio hexahedral elements (a ratio of 5-10 would be fine). However, I am having difficulty controlling the growth of the tetrahedral elements and am achieving instead aspect ratios in the range of 2-4. Thus, there is a very large number of elements penalty for using this rapid mesh generation method. Any ideas as to how to generate elements with aspect ratios in the pipe-like regions (as would easily be done with a block structured hexahedral mesh)? I would like to get the number of elements penalty down to 10-25%, ideally. |
[ANSYS Meshing] High Aspect Ratio Geometry | jreiter164 | ANSYS Meshing & Geometry | 0 | October 19, 2015 23:44 |
[ANSYS Meshing] high aspect ratio | mhdmk | ANSYS Meshing & Geometry | 1 | October 12, 2014 19:54 |
[GAMBIT] High aspect ratio | RGRUIZ | ANSYS Meshing & Geometry | 17 | September 21, 2010 02:24 |
mesh for a high aspect ratio geometry | matthias | CFX | 3 | October 20, 2006 02:55 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
