[ANSYS Meshing] asking about multi domain conformal mesh in Ansys Meshing 17.2 |
teguh hady
Rep Power: 17 ![]() |
Dear all,
I want to simulate heat transfer in corrugated coil tube in Ansys Meshing 17.2. The fluid domain in split in two small domain to make mesh easy and the solid domain. I have problem with conformal mesh in Fluid domain. Actually, I have tried this for fluid domain only by use this tutorial https://youtu.be/N-eOwfYiysE however, when I use three domains 2 fluids and 1 solid, the meshing is not conform in fluid domains. I use shared topology in Design Modeller to make these three domains to share the topology into one. Is the conformal mesh in shared topology can be applied only fluids zone? Do you have any suggestion? Thank you Best regards Teguh
Now Or Never!!! ![]() |
conformal-mesh, corrugated-coil, multi-domain |
[ANSYS Meshing] Extruding 2D mesh to 3D mesh in ANSYS meshing | Rachit | ANSYS Meshing & Geometry | 10 | February 14, 2024 08:19 |
ANSYS Meshing + CFX Pre - Mesh Connection/Domain Interface Definition | mcclud | ANSYS | 5 | February 18, 2020 12:29 |
[ANSYS Meshing] Is it possible to generate mesh in different cell zones in Ansys meshing? | aja1345 | ANSYS Meshing & Geometry | 0 | October 3, 2018 14:22 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
