[TurboGrid] Hub and shroud offset of export points of an axial stator of a turbine
Old   January 26, 2017, 21:58
Default Hub and shroud offset of export points of an axial stator of a turbine
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Hello, I have a stator blade and i want to use turbogrid for meshing, the blade height is 3.45 mm and i found that I cannot export the points with this small height, after increasing it to 30 mm I found no problem and the hub/shroud offset was 5.9% and this is ok...Any idea to generate the mesh with the 3.45 mm height?
Thanks
Ahmed Saeed Mansour is offline   Reply With Quote
Old   May 27, 2020, 09:53
Michael Jeremy
michaelsinaga is on a distinguished road
hey how can you reduce the hub/shroud offset ? ive got a problem with too large of it.
michaelsinaga is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[DesignModeler] Define FlowPath for axial turbine giangcoikx ANSYS Meshing & Geometry 1 September 29, 2016 18:06
[TurboGrid] Wind turbine: problem with the hub radius MrDaimon ANSYS Meshing & Geometry 0 March 12, 2015 08:12
[TGrid] Water Turbine meshed in TurboGrid: Geometry and Topology issues ama294 ANSYS Meshing & Geometry 12 September 29, 2014 13:23
How is Hub to Shroud Line drawn in CFX by default? arunraj CFX 0 October 14, 2011 07:36
