[ANSYS Meshing] 2D meshing issue for multi-line-segment shapes
Old   May 31, 2020, 10:05
Default 2D meshing issue for multi-line-segment shapes
Erica
Magneto2008 is on a distinguished road
Hi Everyone,
I am trying to mesh a 2D geometry created in Solidworks. It's an external geometry. I'm using Ansys workbench and the geometry imports just fine, but when I click on the meshing tab, I get an error that says "Plugin error: No valid bodies found for 2D analysis in the following parts: <filename>". I seem to have traced the problem to the fact that my Solidworks surface body has multiple line segments that make up the inner body, as I was able to get everything to work for a similar file which just has one continuous line as the inner body. I'm attaching links two Solidworks files, one that worked and one that didn't (sorry, system won't let me upload the files directly.)
https://www.dropbox.com/s/djgb0k8cgs...rk.SLDPRT?dl=0
https://www.dropbox.com/s/bqhk7e7rn8...ks.SLDPRT?dl=0
Any thoughts on what I should do to get rid of the error?
Thanks very much,
Erica
Magneto2008 is offline   Reply With Quote
2d geometry, external geometry, line segments, solidworks import
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Derivative of velocity and mean velocity hiuluom OpenFOAM Post-Processing 1 May 29, 2015 23:42
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
