[ANSYS Meshing] MultiZone not creating uniformly sized mesh |
June 5, 2020, 10:24 |
Anthony
Rep Power: 5 |
Hey everyone, I have been using MultiZone to generate a uniform mesh on a part with 2 separate bodies, and generally it has been working fine, and produces a mesh like so on the interior body:
FLAT1.PNG However, when I modify the geometry slightly to include interruptions, the mesh stops being uniform and turns out like so: INTERRUPT1.PNG I am using edge sizing on all the vertical edges to coarsen the mesh in the y-direction which has worked fine until now, however it seems that in this case it causes the whole mesh to coarsen. I have tried using body sizing to force the smaller mesh in the other directions but to no avail. Any ideas how I could get around this? |
July 1, 2020, 04:04 |
Gwenael H.
Rep Power: 20 |
Hi Anthony,
What do you mean by "interruptions" ? If there are small indents that you try to mesh as well between the different bodies you'll need to help the multizone method. Also it can depend on which body the mesher is starting with > you can control that with named selection and meshing steps. |
ansys meshing, multizone, uniform meshing in fluent |
[solids4Foam] MultiMaterial in FSI problems | Hgholami | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 12 | July 7, 2021 19:18 |
Creating Volume mesh from surface mesh | Vivek.oswal | Mesh Generation & Pre-Processing | 0 | August 7, 2015 14:11 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
