June 10, 2020, 05:58 |
Generating Mesh on HPC
Ciaran Parker
Hi there,
I have been running an experiment using a HPC, Linux cluster, and I'm struggling with the meshing part. Due to the complexity of the mesh, I can't run it on the login node, and need to submit it as a job script to a separate node, but I am unsure how. I have set all the necessary sizing and other properties for the mesh, I just need to generate it on one of the computing nodes. I have read on other posts on this forum that it may require a java script, instead of a Python which is used for Fluent job scripts, but I am unsure. Operating a HPC / using Linux is new grounds to me, so any help on the matter would be greatly appreciated. Kind regards, Ciaran. |
hpc, job script, meshing |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[mesh manipulation] Generating a single cell mesh using a patch of a 3d mesh | kebsiali | OpenFOAM Meshing & Mesh Conversion | 3 | May 30, 2016 06:36 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
