[ICEM] Issue with merging meshes
Old   May 14, 2017, 02:02
Question Issue with merging meshes
Prem Sagar
PremSagar is on a distinguished road
Hi!
I wanted to mesh an interior part of my domain. Since I wanted non conformal mesh, I figured I'll create sub-topologies and merge two different hexahedral meshes. I have attached the pictures for reference. I ran the mesh check and I was able to fix uncovered faces. But new problems arised:
1. Multiple edges
2. Non-manifold vertices
3. Penetrating elements
I couldn't quite figure out how to deal with these. The 'fix' option I encountered on the fly didn't seem to work because they popped up again the second time I run the mesh check. So what can I do to avoid these issues?
Thanks in advance!
PremSagar is offline   Reply With Quote
Old   June 19, 2020, 08:26
lbj007 is on a distinguished road
Hi,did you solve it? I also have the same problem
lbj007 is offline   Reply With Quote
icem 16.2, mesh merge, multiple edges, non manifold vertices
bad momentum source, vortice direction with twoPhaseEulerFoam and non-ortho meshes cutter OpenFOAM Running, Solving & CFD 7 November 17, 2016 14:17
scalarTransportFoam issue with dynamic meshes Thangam OpenFOAM Programming & Development 5 August 18, 2015 15:52
[Other] Can't import airfoil meshes successfully klausb OpenFOAM Meshing & Mesh Conversion 7 May 26, 2015 15:51
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 03:33
