September 8, 2020, 04:11 |
Swirler Geometry Creation
Rajasthan
I am trying to create a swirler (or de-swirler) geometry, it is similar to an impeller, however with a slight difference, the angle of the helix doesn't stay constant across the hub length.
I will be really grateful if you could look upon the attached images and suggest a way to achieve a similar geometry, using any tool (preferably Design Modeler) you think is appropriate. I could create an approximate geometry using spaceclaim (using face curve tool), but it isn't a very accurate method. I am also attaching 2-d design given in Text Book 'Alex C. Hoffmann, Louis E. Stein, Gas Cyclones and Swirl Tubes'. Thanks Last edited by iamkundan; September 8, 2020 at 04:12. Reason: attaching image of 2d design by AC Hoffman |
swirler, vanes |
[ICEM] Work with imported STL geometry | KateEisenhower | ANSYS Meshing & Geometry | 2 | July 9, 2015 10:46 |
Importing ccm file - Creation of geometry part from boundary | crevoise | STAR-CCM+ | 1 | January 10, 2013 03:17 |
[DesignModeler] geometry creation | kmgraju | ANSYS Meshing & Geometry | 0 | November 18, 2012 22:30 |
Best free tool for Geometry creation | mmkr825 | OpenFOAM | 12 | October 8, 2012 02:53 |
star ccm+ new geometry part creation | krishna086 | STAR-CCM+ | 0 | November 24, 2010 11:17 |
