[ICEM] [ICEM] How to use Split Wall command?
Old   February 12, 2021, 10:57
Default [ICEM] How to use Split Wall command?
MWRS
waseeqsiddiqui is on a distinguished road
Hi all. I have a question about the split wall option. If applied to a single surface, it has overlapping set of elements on each side of it. I have observed the following two features:-
1) Check mesh shows surface orientation and overlapping element error.
2) Fluent says "there is only one adjacent cell thread" and declares it as wall.
3) Fluent would make it interior but the behavior of the surface would be as wall and barrier to flow field.
I want to make it interior volume surface. How do I do that? Thank you
waseeqsiddiqui is offline   Reply With Quote
Two phase flow in porous medium Milaad OpenFOAM 6 December 15, 2020 07:55
What's the problem with turbulence models near the wall region? Jaydi_21 Main CFD Forum 6 July 7, 2017 02:39
Radiation interface hinca CFX 15 January 26, 2014 17:11
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
