[ANSYS Meshing] Pointwise volume meshing problems
Old   April 3, 2021, 06:46
Default Pointwise volume meshing problems
Pietro Loporcaro
pietro_lopo is on a distinguished road
Hi guys, i'm starting to learn how to use Pointwise.
I've to mesh a car floor in a control volume but i have some difficulties.
My geometry is a car floor, made on CATIA, i've been able to import my .igs file and it has been located in the 'database' tab.
Then i used a script to create a rectangular prism, which already has connectors and points.
After i used the function 'connectors on database entities' on my database (the floor geometry), and i've been able to mesh my floor but i've no clue on how meshing the volume in my interest (control volume-floor volume).
Some advice?
Thanks
pietro_lopo is offline   Reply With Quote
fluent, pointwise mesh
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[ANSYS Meshing] Failed Volume Mesh + Meshing takes long times StarCFD ANSYS Meshing & Geometry 8 February 18, 2015 19:38
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 06:44
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
