April 3, 2021, 07:36 |
ICEM default stretching
Rep Power: 5 |
I am having an issue regarding ICEM meshing. I am trying to mesh this far field boundary (images attached), but without the geometric stretching. I have applied the stretching to one end of the edge, but although I have 0m spacing on the side '1', it shows that there is some stretching. Any ideas? |
April 3, 2021, 10:51 |
Kira
Rep Power: 8 |
That's what the BiGeometric mesh law does. If you want to get rid of that and make it uniform, use the Uniform Mesh Law. If you want to increase the density of nodes on only one side, you need to use Geometric 1 or 2.
[Workbench] ICEM failing to update mesh in a Workbench flow project | VladCFD | ANSYS Meshing & Geometry | 7 | July 2, 2020 02:53 |
[ICEM] Cannot update new.3dm file in ICEM based on rpl file | jimmy871013 | ANSYS Meshing & Geometry | 3 | June 20, 2017 11:02 |
Cannot update new.3dm file in ICEM based on rpl file | jimmy871013 | Mesh Generation & Pre-Processing | 1 | June 20, 2017 02:21 |
Design Modeler to ICEM..... | Joe | CFX | 0 | January 24, 2008 03:39 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 06:46 |
