[ANSYS Meshing] Reversal of named selection faces |
July 29, 2021, 15:18 |
Adithya
Rep Power: 4 |
Hello
Something very strange happened. I created a duplicate of a mesh instance on workbench. After that, in the original mesh instance, my named selection faces were swapped. For example, I have a 'right wing' and a 'left wing'. The named selection faces are correct in design modeler. But, in meshing, they suddenly got swapped. The show the other face. This is true for 6 such pairs Did I accidently click on something? Or is this is a bug? How do I correct this? |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
