[ICEM] ICEM Mesh: Curved Mesh number of nodes undesired
Like Tree1Likes
  • 1 Post By Stel
Old   August 25, 2021, 16:01
Default ICEM Mesh: Curved Mesh number of nodes undesired
julian_007 is on a distinguished road
Dear Community,
as a ICEM beginner I have the following problem.
As you can see in the picture I want to mesh a curved inlet of an seal, best practice example is shown on the left.
On the right, part of my blocking strategy is to associate the diagonal line to the curve of the inlet, shown by the small arrow. On the lines I set the desired numbers of nodes, e.g. 10, 5, 6, "copy parameters to all parallel edges" is turned off.
The number of nodes 14 is caculated by icem itself, also the red number 6.
My question is why the red number is not higher than 6?
The third picture shows the actual mesh, with small elements, which cause a failed mesh.
Has someone an idea how can I reach the desired mesh, like in the first picture?
Thank you for your help!
julian_007 is offline   Reply With Quote
Old   August 25, 2021, 16:52
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
julian_007
Could you re-load the pictures? I think they were not properly attached.
alainislas is offline   Reply With Quote
Old   August 25, 2021, 17:17
Originally Posted by alainislas View Post
julian_007
Yes, of course here seperatly:
1. picture: https://www.cfd-online.com/Forums/me...sired-mesh.png
2. picture: https://www.cfd-online.com/Forums/me...odes-lines.png
3. picture: https://www.cfd-online.com/Forums/me...-mesh-fail.png
Old   August 31, 2021, 14:48
Henrique Stel
Stel is on a distinguished road
Still can't see any of the images.
Stel is offline   Reply With Quote
Old   August 31, 2021, 16:27
Kira
aero_head is on a distinguished road
Julian,
Please follow the steps here: http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F to attach your photos.
aero_head is offline   Reply With Quote
Old   September 1, 2021, 06:30
now it should work, I hope!
Old   September 3, 2021, 01:29
Kira
Looks good now, Julian.
Which mesh laws are you using? As well, are you using linked bunching or not?
Just trying to get a sense of the steps you performed to create the mesh.
Old   September 3, 2021, 16:10
Henrique Stel
Because it seems that, with your current blocking strategy, the vertical edge on the left-hand side is parallel to the vertical edge on the right-hand side (which also has 6 nodes). Turning the "Copy parameters to all parallel edges" option off only avoids ICEM to copy the mesh law, not the number of nodes (in a pure structured mesh, parallel edges will have equivalent number of nodes).
The example you have shown uses non-mapped blocks. I would prefer and O-Grid strategy around the round corner on the upper right-hand side.
aero_head likes this.
Old   September 4, 2021, 15:49
Thank you Stel, for the answer!
Now I'm this far with the mesh, second picture. I created a "cross" in the midpoint of the curve, as you can see in the first picture.
On the right the mesh volumes are still getting very small unfortunely...
how can this be avoided? How do I implement an O Grid in this round edge?
(I didn't use any bunching laws, just BiGeometric @aero_head
Thanks in advance!
Old   September 6, 2021, 13:21
Henrique Stel
Could you give more details about the geometry?
Old   September 6, 2021, 16:43
alainislas's Avatar
Alain Islas
From one of your previous pictures, you need a L-grid at the round corner. You can introduce some splits as illustrated. Just extrapolate this strategy for your 3D block
curved mesh, number of nodes
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 03:58
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
