[ICEM] ICEM - 3D MultiZone - Wing-Fuselage Configuration
Old   September 9, 2021, 00:42
Default ICEM - 3D MultiZone - Wing-Fuselage Configuration
bakar
abu.bakar.ist is on a distinguished road
Hi all !
I am making grid for fuselage-Wing configuration using ICEM CFD. The steps are as :
1. geometry and topology build
2. Create block -> 3d Multizone
3. Move/merge vertices, Split Free Face
4. Modify mesh size of different surfaces for smooth mesh.
5. Convert free faces to mapped (wing leading edge, wing upper and lower
surface)
The resulting mesh is shown below.
6. Now, there are 300 mesh point along the airfoil.
7. I need to increase it to 600. So I decrease the mesh size on upper and lower surface of wing. Now I am getting two types of errors.
ERR 3105: boundary node lies within face near (xxxxx, yyyyy, zzzz)
ERR 3009: edge near (xxxxx, yyyyy, zzzzz) is missing
I have also checked surface mesh at these location. Mesh looks fine.
Is there any solution for this problem.
Thanks
abu.bakar.ist is offline   Reply With Quote
ICEM Wing Mesh Problem andrewmichael Mesh Generation & Pre-Processing 0 March 4, 2018 17:30
[ICEM] 3D wing + wingtip meshing in ICEM AdriC ANSYS Meshing & Geometry 3 February 22, 2016 11:14
[ICEM] unstructured wing mesh generation in ICEM CFD arunintn ANSYS Meshing & Geometry 3 March 6, 2013 17:05
Negative Fuselage Drag on a Tandem Wing? mmn1239 STAR-CCM+ 3 April 28, 2012 08:20
Negative Fuselage Drag on a Tandem Wing? mmn1239 Main CFD Forum 1 April 7, 2012 04:52
