[ANSYS Meshing] Inflation layer is not able to be sweeped in my case.!
Old   March 19, 2022, 01:11
Default Inflation layer is not able to be sweeped in my case.!
Abu_sidddique is on a distinguished road
Hi Im trying to mesh a multi element airfoil in 3D domain with 1mm extrusion length in z direction. Im using sweep method to mesh the volume with one sweep element. I selected manual source and target option in order to get the required results. I could able to sweep the edge sizing parameter on the front face properly. But when i try to use the inflation layer it is not able to mesh. Different errors pop up with different settings and i could not mange to get it work. Any help on this would be more helpful.!
Abu_sidddique is offline   Reply With Quote
Old   March 23, 2022, 08:55
siw
Stuart
siw will become famous soon enough
It should work (I just did a test using a circular hole instead of an aerofoil in Ansys 2021 R2).
A few questions:
1) How are you applying the MultiZone? In my test I select Sweep Size Behaviour = Sweep Edges and the 4 z-axis edges at the Sweep Edges. This made 4 elements in the z-direction so I used an Edge Sizing with 1 Division and Behaviour = Hard to enforce 1 element in the z-axis.
2) How are you applying the Inflation? I RMB on MultiZone to select Inflate This Method and for Boundary = Face of the hole (or aerofoil for you).
Lastly, I used an Edge Sizing in the hole (aerofoil for you) on one edge only - the edge on the MultiZone sweep direction to refine on the hole.
The only difference I see with the aerofoil is the difficulty in the inflation layer going around the sharp trailing edge. If so, increase the global Inflation (View Advanced Behaviour) > Maximum Angle = 180 deg (from 140 deg).
siw is offline   Reply With Quote
Old   March 24, 2022, 00:23
thank you so much for the helpful reply. I will try out these methods and update the results in this post.
Thanks again.
Importance of inflation layer for calculating drag force for a heavy duty truck Melikmemmed CFX 6 January 24, 2021 16:49
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh Dikkeunit OpenFOAM Meshing & Mesh Conversion 0 February 3, 2020 09:46
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 09:43
[ANSYS Meshing] Inflation layer / Element quality Spookz ANSYS Meshing & Geometry 17 February 12, 2019 04:55
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
