[Other] What are the geometric parameters to be able to draw a centrifugal pump? |
August 26, 2022, 03:45 |
Zeinab Abosedaira
Rep Power: 4 |
Hello all,
I need to replicate the results of some paper on a centrifugal pump and create the geometry for it. So, the paper gives some geometric parameters but I don't need whether this is enough or not. The pump type is mentioned but when I search it only gives me performance data. The pump type is IS125-100. The below geometric parameters are mentioned. pump1.PNG pump2.PNG My question is whether this information is enough for creating a model, and what is the best Ansys product to draw with? If it's not enough, what is the best practice, can I find the data somewhere? |
August 26, 2022, 08:28 |
Daniel
Rep Power: 9 |
Well, are you planning on a 1to1 replica of the shown model? Because then, you would need really more informations than just the basic dimensions of outlet width, outlet diameter and blade count.
Very important for you would be the wrap angle of the blade. This would be hard to get, in my opinion. But, if the image is true, the blade seem to be 2D which makes it easy to create once one blade profile is found or calcualted. In general, you can use the Bladegen tool for creating blade geometries. |
August 29, 2022, 05:19 |
Zeinab Abosedaira
Rep Power: 4 |
Great Thank you.
And how can I get the profile of one blade or calculate it? Thank you! |
August 29, 2022, 05:35 |
Daniel
Rep Power: 9 |
Maybe you can work with the relative outlet angle of the pump, if it is given.
I would suggest you look into the book "Centrifugal Pumps" by Gülich. Chapter 7.2.2.2 covers the blade design. You could approximate the wrap angle from the image you got and try to iterate through manual calculations until you maybe reach the design (relative angle distribution from inlet to outlet) you want to have. |
centrifugal pump, geometry |
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop | olivier | OpenFOAM | 8 | October 29, 2018 07:49 |
problem for centrifugal pump transient simulation | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | January 15, 2014 04:55 |
simulating a submerged double impeller centrifugal pump | sandy_1982 | CFX | 5 | August 16, 2013 09:05 |
ERCOFTAC centrifugal pump | vngrsrmn | OpenFOAM | 0 | June 20, 2012 06:51 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
