[ICEM] How to specify inflation layers around a curved surface in ICEM CFD? |
August 31, 2022, 05:34 |
Murali Krishnamraju
Rep Power: 4 |
bottom_and_cylinder.jpg Domain.jpg Mesh_section2.jpg Side_view.jpg I am trying to develop Hexa mesh in a flow domain with a scour hole around the bottom of the cylinder. The flow domain is shown in the figure. The cylinder and the bottom surface are treated as walls, so an inflation layer must be provided around them. To provide the inflation layer to the bottom surface with scour hole, first layer thickness, growth rate and the number of layers are provided to the edges 1,2,3,4, 10,11,12 and 13 (as shown in the blocking figure). But the edge properties provided to the edges 1,2,3,4 are getting copied to all the parallel edges (edges 5,6,7,8,9 and the edges in the same row). It leads to the development of inflation layers above the bottom surface in the scour hole region (as shown in the attached figure). I need the inflation layer only to the bottom surface in the scour hole region but not above it. Please suggest possible solutions to this problem. |
hexa blocking, hexa mesh, hexa meshing, icem 19.2, icem cfd meshing |
[ICEM] Surface ID in ICEM CFD | RAJDEEP | ANSYS Meshing & Geometry | 2 | May 2, 2021 03:05 |
[ANSYS Meshing] Not so pretty Inflation on a curved surface | kyo022 | ANSYS Meshing & Geometry | 3 | November 29, 2017 07:13 |
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface | James Date | CFX | 3 | August 10, 2012 04:47 |
[Gmsh] Layers in a curved surface | Artex85 | OpenFOAM Meshing & Mesh Conversion | 1 | December 18, 2011 08:51 |
surface in icem cfd | Rogerio Fernandes Brito | CFX | 1 | July 22, 2008 17:46 |
