[Other] How to create a perfectly flat surface in Spaceclaim?
Old   November 8, 2022, 19:54
Default How to create a perfectly flat surface in Spaceclaim?
Lucas Pelizzari
lpelizzari is on a distinguished road
I have the geometry of an airplane cut in half, like this:
To generate the fluid domain in Spaceclaim, I have to create a rectangle around the geometry at the plane of symmetry and then extrude it (correct me if I'm wrong).
The problem with that is, when I fill the remaining face of the geometry like this:
it creates a not-flat surface, which absolutely ruins the fluid domain generation step.
It is barely noticeable here, but you can see the surface bulges out just a little bit.
When I try to cut one surface from the other, it actually works, but it creates a hole in the fluid domain.
How do I generate an actually flat surface in this situation?
lpelizzari is offline   Reply With Quote
spaceclaim
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 09:26
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 18:28
[snappyHexMesh] How to create internal boundaries using snappyHexMesh robyTKD OpenFOAM Meshing & Mesh Conversion 2 October 19, 2014 09:57
[DesignModeler] Design Modeller create surface papis ANSYS Meshing & Geometry 0 October 31, 2013 13:52
