November 28, 2022, 08:56 |
Airfoil blades meshing
Shehabeldeen
Rep Power: 4 |
Helllo everybody
Am facing a great problem , My geometry is as follow : Outer domain ( BOX) Inner domain ( Cylinder ) Inside the inner domain there is Turbine with airfoil blade profile When I generate the mesh the orthogonal quality is very low in range of 5 time 10 to the power -3 something like that I tried alot to improve the mesh quality but nothing works beside that i can not even add inflation beyond the blades Any help please thanks in advance |
airfoil, naca, savonius, turbines |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[snappyHexMesh] Slat base flap airfoil meshing with snappyhexmesh | andreape | OpenFOAM Meshing & Mesh Conversion | 1 | May 6, 2020 16:41 |
[ANSYS Meshing] Face Meshing around an airfoil with a flap | franzshady99 | ANSYS Meshing & Geometry | 0 | November 29, 2019 11:28 |
[ANSYS Meshing] Problem meshing airfoil with dimple | Janet | ANSYS Meshing & Geometry | 5 | August 27, 2019 02:58 |
[GAMBIT] Problematic meshing of an inverted airfoil | snkutta | ANSYS Meshing & Geometry | 2 | October 11, 2011 13:23 |
