[ANSYS Meshing] Unique undersired results appearing in Meshing |
July 5, 2023, 06:08 |
Prayan
Rep Power: 2 |
I am using ansys meshing to mesh a 2d sinusoidal geometry. I have already done it many times on this geometry but however, ansys now decides to give some unique error.
I am sharing the google drive link wherein a desired mesh and an outcome mesh is displayed. Also, the geometry is attached that marks geometry is free from issue. Last edited by pranay10; July 6, 2023 at 08:16. Reason: External Link Removed and Attachments added |
July 6, 2023, 07:56 |
Gert-Jan
Rep Power: 27 |
Don't use external links. I won't open them!
Use this quide line on how to post images on this forum. https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F |
July 6, 2023, 08:17 |
Prayan
Rep Power: 2 |
Thank You for the suggestion. I edited it. Kindly help.
July 6, 2023, 08:24 |
Gert-Jan
Rep Power: 27 |
Difficult to say.
In my experience, ANSYS mesher prefers a number of small surfaces above a single large surface. Especially when it is a spline and build up of a lot or curves, possibly like yours. Difficult to judge from these images. In any case, better chop it into smaller pieces. As an example. I never use surfaces of 360° when I try to mesh a cilinder. Then I always use 2 surfaces of 180°. Then the mesher has additional line to start meshing or to attached elements to. That often help. |
mesh, pipe |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Icem meshing queries | Mfaizan | ANSYS Meshing & Geometry | 21 | July 30, 2015 23:10 |
Meshing software comparison | Wikie | Mesh Generation & Pre-Processing | 5 | September 29, 2014 06:09 |
is free meshing or mapped meshing is best for flow problems | shanu | Main CFD Forum | 0 | February 18, 2010 11:58 |
[Other] is free meshing or mapped meshing is best for flow problems | shanu | OpenFOAM Meshing & Mesh Conversion | 0 | February 18, 2010 11:56 |
