July 2, 2023, 16:00 |
Help to impove mesh qualit
Doug
Rep Power: 16 |
Please, any idea how to improve the mesh qualit in the figures attached?
thanks. |
July 2, 2023, 16:12 |
Daniel
Rep Power: 9 |
Your expansion ratio in Figure 1 on the left side seems way too high. Make the expansion ratio go more smoothly.
In figure 3 that might also be the case at the boundary of the two sections. Also, I assume, that the angle of the element will not be good. Something may be off with one node or so. |
July 2, 2023, 17:12 |
Doug
Rep Power: 16 |
Thank for helping me!
I am relatively new on ICEM I tried, and this this happened, I don't know why... |
July 3, 2023, 02:02 |
Daniel
Rep Power: 9 |
Maybe, you need to search for some tutorials on ICEM to get a bit more familiar with the functions.
July 5, 2023, 06:03 |
Chrowale
Rep Power: 4 |
Could be association issue and also could be wrong method to create the blocking. Did you combine any vertices while creating the block?
July 6, 2023, 18:53 |
Doug
Rep Power: 16 |
Thank you for helping!
It was an association issue. The edges were automaticaly assossiated to the surfaces. I removed them, than it worked!! Best wishes! Last edited by dulls; July 10, 2023 at 14:39. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[snappyHexMesh] High quality mesh for wind in complex urban environment | ziboaa | OpenFOAM Meshing & Mesh Conversion | 1 | January 12, 2021 15:33 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] Bad Quality Hybrid Mesh External Flow | tim13 | ANSYS Meshing & Geometry | 0 | March 8, 2020 02:22 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
