[DesignModeler] TE irregularities due to CAD import in Designmodeler
Like Tree1Likes
  • 1 Post By Muki
Old   July 10, 2023, 11:28
Default TE irregularities due to CAD import in Designmodeler
Mukilan S
Muki is on a distinguished road
I'm trying to simulate a ducted fan's blade in CFX, for which I am trying to mesh with Turbogrid. It keeps throwing this error 'Mesh too coarse to successfully create tip mesh'. So I went back to the CAD to check for sharp TE and found out that my geometry has irregularities when imported into Designmodeler. But the same CAD has a smooth TE while I opened it in Autodesk Inventor. Is there any way to solve this issue??
I have attached images of my TE.
Thanks in advance!!
Muki is offline   Reply With Quote
Old   July 21, 2023, 13:09
Mukilan S
The problem has been sorted. It seems that a .stp file doesn't make any effort to smoothen any unintentional or undesirable irregularities in the geometry. Inventor generally does this cleaning to all the CAD that is being opened through it. Ansys Designmodeler, on the other hand, doesn't do it. So, I adopted another format of the same file, that is, a Parasolid file. This takes care of this cleaning. Hence now, I'm able to mesh my geometry seamlessly.
Hope this helps someone who faces similar issue.
Thanks !!!
zacko likes this.
NX Siemens CAD import Error: java.net.SocketException: Connection reset Xander STAR-CCM+ 1 September 8, 2023 02:24
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 15:35
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
Import to DesignModeler zelito ANSYS Meshing & Geometry 0 December 15, 2009 14:33
I-DEAS CAD data import with boundary conditions Yunus FLUENT 2 March 14, 2001 14:45
