[ANSYS Meshing] Automatic Script for Named Selections of a Volute |
August 4, 2023, 08:18 |
Daniel
Rep Power: 9 |
I'm trying to write a python script for ANSYS Meshing. For now, the ANSYS Scripting guide for Mechanical does only help to a certain point. What I try to achieve: I want to automate the naming of faces of a volute. These are: Outlet, Interface, Symmetry and Walls. I wrote the script to name the Outlet, Interface and Symmetry Face based on the face areas. For the symmetry, since it is the biggest plane, I used the function: Code:
SelectionOperatorType.Largest All other faces, that are not selected yet, shall be placed in a selection called Walls. I tried it with putting every face into Walls first, using a face area > 0.0 mm. And then start the naming of the other faces. But, the other faces are sadly not excluded of the Walls selection afterwards. Is there a good option about using connections? Or any other method? Attached an image of an exemplary volute and the named selection up until now and the code. Also, I assume there must a better way to code my named selections. Code:
sel = Model.AddNamedSelection() sel.ScopingMethod=GeometryDefineByType.Worksheet b3 = 0.3 D3 = 0.73 Dd = 0.8 bool_symmetry = True if bool_symmetry == True: A_interface = 0.5*(pi * D3 * b3) A_discharge = 0.5*(pi/4 * Dd**2) # DISCHARGE sel.Name = "VOLUTE_OUTLET" discharge = sel.GenerationCriteria discharge.Add(None) discharge[0].EntityType=SelectionType.GeoFace discharge[0].Criterion=SelectionCriterionType.Size discharge[0].Operator=SelectionOperatorType.RangeInclude discharge[0].UpperBound = Quantity(A_discharge*1.01 ,"m m") discharge[0].LowerBound = Quantity(A_discharge*0.99, "m m") sel.Generate() # SYMMTERY sel_sym = Model.AddNamedSelection() sel_sym.ScopingMethod=GeometryDefineByType.Worksheet sel_sym.Name = "VOLUTE_SYMMETRY" symmetry = sel_sym.GenerationCriteria symmetry.Add(None) symmetry[0].EntityType=SelectionType.GeoFace symmetry[0].Criterion=SelectionCriterionType.Size symmetry[0].Operator=SelectionOperatorType.Largest sel_sym.Generate() # INTERFACE sel_itf = Model.AddNamedSelection() sel_itf.ScopingMethod=GeometryDefineByType.Worksheet sel_itf.Name = "VOLUTE_INTERFACE" interface = sel_itf.GenerationCriteria interface.Add(None) interface[0].EntityType=SelectionType.GeoFace interface[0].Criterion=SelectionCriterionType.Size # I use RangeInclude, because the Equal command does not find the face (maybe rounding error?) interface[0].Operator=SelectionOperatorType.RangeInclude interface[0].UpperBound = Quantity(A_interface*1.01 ,"m m") interface[0].LowerBound = Quantity(A_interface*0.99, "m m") sel_itf.Generate() Thank you for your help. Daniel |
[ANSYS Meshing] Use of replay script for automatic meshing for the same kind of Geometry in ICEM | ruchit@15847 | ANSYS Meshing & Geometry | 1 | June 7, 2022 20:20 |
[OpenFOAM] Using python script for automatic post processing of openFoam | vPaquet | ParaView | 12 | December 16, 2021 03:30 |
[DesignModeler] Macro / Script for automatic geometry import | wasabi | ANSYS Meshing & Geometry | 26 | August 25, 2018 19:03 |
[ICEM] Save Message Log automatic with Replay Script | survADe | ANSYS Meshing & Geometry | 3 | July 11, 2013 05:49 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
