[ANSYS Meshing] Automatic Script for Named Selections of a Volute
Old   August 4, 2023, 08:18
Post Automatic Script for Named Selections of a Volute
Daniel
zacko is on a distinguished road
I'm trying to write a python script for ANSYS Meshing.
For now, the ANSYS Scripting guide for Mechanical does only help to a certain point.
What I try to achieve:
I want to automate the naming of faces of a volute. These are: Outlet, Interface, Symmetry and Walls.
I wrote the script to name the Outlet, Interface and Symmetry Face based on the face areas. For the symmetry, since it is the biggest plane, I used the function:
SelectionOperatorType.Largest
That works fine.
All other faces, that are not selected yet, shall be placed in a selection called Walls.
I tried it with putting every face into Walls first, using a face area > 0.0 mm. And then start the naming of the other faces. But, the other faces are sadly not excluded of the Walls selection afterwards.
Is there a good option about using connections? Or any other method?
Attached an image of an exemplary volute and the named selection up until now and the code. Also, I assume there must a better way to code my named selections.
sel = Model.AddNamedSelection()
sel.ScopingMethod=GeometryDefineByType.Worksheet
b3 = 0.3
D3 = 0.73
Dd = 0.8
bool_symmetry = True
if bool_symmetry == True:
    A_interface = 0.5*(pi * D3 * b3)
    A_discharge = 0.5*(pi/4 * Dd**2)
# DISCHARGE
sel.Name = "VOLUTE_OUTLET"
discharge = sel.GenerationCriteria
discharge.Add(None)
discharge[0].EntityType=SelectionType.GeoFace
discharge[0].Criterion=SelectionCriterionType.Size
discharge[0].Operator=SelectionOperatorType.RangeInclude
discharge[0].UpperBound = Quantity(A_discharge*1.01 ,"m m")
discharge[0].LowerBound = Quantity(A_discharge*0.99, "m m")
sel.Generate()
# SYMMTERY
sel_sym = Model.AddNamedSelection()
sel_sym.ScopingMethod=GeometryDefineByType.Worksheet
sel_sym.Name = "VOLUTE_SYMMETRY"
symmetry = sel_sym.GenerationCriteria
symmetry.Add(None)
symmetry[0].EntityType=SelectionType.GeoFace
symmetry[0].Criterion=SelectionCriterionType.Size
symmetry[0].Operator=SelectionOperatorType.Largest
sel_sym.Generate()
# INTERFACE
sel_itf = Model.AddNamedSelection()
sel_itf.ScopingMethod=GeometryDefineByType.Worksheet
sel_itf.Name = "VOLUTE_INTERFACE"
interface = sel_itf.GenerationCriteria
interface.Add(None)
interface[0].EntityType=SelectionType.GeoFace
interface[0].Criterion=SelectionCriterionType.Size
# I use RangeInclude, because the Equal command does not find the face (maybe rounding error?)
interface[0].Operator=SelectionOperatorType.RangeInclude
interface[0].UpperBound = Quantity(A_interface*1.01 ,"m m")
interface[0].LowerBound = Quantity(A_interface*0.99, "m m")
sel_itf.Generate()
Maybe you have better resources of ANSYS that I haven't found yet?
Thank you for your help.
Daniel
zacko is offline   Reply With Quote
[ANSYS Meshing] Use of replay script for automatic meshing for the same kind of Geometry in ICEM ruchit@15847 ANSYS Meshing & Geometry 1 June 7, 2022 20:20
[OpenFOAM] Using python script for automatic post processing of openFoam vPaquet ParaView 12 December 16, 2021 03:30
[DesignModeler] Macro / Script for automatic geometry import wasabi ANSYS Meshing & Geometry 26 August 25, 2018 19:03
[ICEM] Save Message Log automatic with Replay Script survADe ANSYS Meshing & Geometry 3 July 11, 2013 05:49
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
