[ICEM] Weird Meshing of cavity
Old   August 25, 2023, 06:52
Default Weird Meshing of cavity
Hasan
hasano20 is on a distinguished road
Hi there,
I'm new to ICEM and Ansys in general and I need some explanation for an occurence. (See picture)
I tried to redo the block several times but I ended up having the same outcome. As a result I can not run the sim as parts of it are now 2D instead of 3D.
Would very appreciate a solution to this problem!
hasano20 is offline   Reply With Quote
Old   August 28, 2023, 04:40
Chrowale
mluckyw is on a distinguished road
Its a bit hard to judge by the picture because you display the block as well as the mesh.
Looks like the mesh is collapsed in the circle mentioned, most likely this is an association problem. You could check the association of each edges by right clicking the "edge" in the tree and select "Show association" and associate accordingly.
mluckyw is offline   Reply With Quote
[ANSYS Meshing] Help with a stl file meshing Legolas_1204 ANSYS Meshing & Geometry 4 March 7, 2023 11:56
[ICEM] Weird meshing error ahsanx ANSYS Meshing & Geometry 1 July 24, 2020 02:30
[ANSYS Meshing] Meshing a cavity in an airfoil kashawki ANSYS Meshing & Geometry 2 July 30, 2015 07:21
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
