August 25, 2023, 06:52 |
Weird Meshing of cavity
Hasan
Hi there,
I'm new to ICEM and Ansys in general and I need some explanation for an occurence. (See picture) Meshing Problem.png I tried to redo the block several times but I ended up having the same outcome. As a result I can not run the sim as parts of it are now 2D instead of 3D. Would very appreciate a solution to this problem! |
August 28, 2023, 04:40 |
Chrowale
Rep Power: 4 |
Its a bit hard to judge by the picture because you display the block as well as the mesh.
Looks like the mesh is collapsed in the circle mentioned, most likely this is an association problem. You could check the association of each edges by right clicking the "edge" in the tree and select "Show association" and associate accordingly. |
[ANSYS Meshing] Help with a stl file meshing | Legolas_1204 | ANSYS Meshing & Geometry | 4 | March 7, 2023 11:56 |
[ICEM] Weird meshing error | ahsanx | ANSYS Meshing & Geometry | 1 | July 24, 2020 02:30 |
[ANSYS Meshing] Meshing a cavity in an airfoil | kashawki | ANSYS Meshing & Geometry | 2 | July 30, 2015 07:21 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
