[ANSYS Meshing] Removing the prism layer from a hexcore mesh created in ANSYS Fluent Watertight Mesh |
October 12, 2023, 02:17 |
Rep Power: 3 |
Hi there,
I am trying to create a hexahedral hex-core mesh for the following nozzle geometry for a compressible flow study,(pictures attached below). The inputs of the mesh are as follows : Local face size ( for nozzle walls and domain boundaries ): 0.5mm Surface mesh size: Min. size: 0.5mm, Max. size: 4mm Boundary Layer: 20 layers with a growth ratio of 1.1 on walls The issue I'm currently facing is the presence of a triangular prism layer on the boundary layer. I'm trying to remove that and make it a hex element as well. Please advise on how I can resolve this issue. Thank You |
[snappyHexMesh] Prism layer collapsing in refinement transition | rubenparedes | OpenFOAM Meshing & Mesh Conversion | 8 | May 13, 2021 10:55 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Improving prism mesh | me3840 | OpenFOAM Meshing & Mesh Conversion | 2 | April 2, 2014 04:37 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
