October 18, 2023, 02:17 |
Turbogrid Meshing
abhishek
Rep Power: 3 |
How can I preserve curves of design modeler into turbogrid meshing?
I have extracted curves or lines from CAD of compressor impeller blade and then I created 'Flowpath' in bladeeditor of design modeler. Then I use 'CAD Import' feature and exported script. Then I run script in another designmodeler. This is how I have now sector model of blade, which includes blade, splitter, shroud , Ported Shroud and hub. This shroud has sharp curves at inlets and I want to preserved that shape as I am going to create an interface with ported shroud. |
October 18, 2023, 03:35 |
abhishek
Rep Power: 3 |
I found a possible solution, in the design modeler, blade editor model settings, I enabled advanced features.
This open up a new option in 'flow path' interpolation mesh size, which I put a value of 2000 * number of blade row. and I am able to preserve the flow path curves. But still when importing into turbogrid because the curve representation is 'Bspline' it was not preserving the curve. I used 'Piece-wise Linear' and together with 'Use True Surface For Projections = true' then it preserved the curve. But it is somehow not allowing to generate mesh at shroud tip. Last edited by shingala; October 19, 2023 at 07:00. |
blade editor, design modeler tutorials, geometry ansys, turbogrid errors |
Secondary Flow Path Meshing for centrifugal pump using TurboGrid | mandar55patil | Main CFD Forum | 0 | April 25, 2022 06:59 |
[Other] Good learning materials for robust meshing techniques in 2021 | FoxInCFD | ANSYS Meshing & Geometry | 0 | November 19, 2021 05:52 |
[Other] TurboGrid - problem with trailing edges ending with hub/shroud curve | TTM | ANSYS Meshing & Geometry | 8 | February 16, 2020 07:11 |
[TGrid] Turbogrid splitter meshing | czm28 | ANSYS Meshing & Geometry | 0 | December 4, 2014 07:48 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
