[DesignModeler] two parts with two bodies vs one part with two bodies for regenerative cooling
Old   February 4, 2024, 09:03
Default two parts with two bodies vs one part with two bodies for regenerative cooling
rami
lamini is on a distinguished road
I am trying to simulate regenerative cooling. I am totally confused. In DesignModeler whether we make two parts with two bodies for solid part and fluid part or we should chose one part with two bodies for liquid and solid knowing that fluid will pass through the solid and heat will be exchanged between the two domains.
I performed both in an attempt to check, but there was a huge difference between the two cases though the models were same.
what is the correct choice in this case please ??
lamini is offline   Reply With Quote
Old   February 6, 2024, 05:48
Default check the link below
rami
https://featips.com/2022/05/23/multi...formal-meshes/
[ICEM] Parts Disappear on Mesh Generation VT_Bromley ANSYS Meshing & Geometry 6 May 16, 2016 14:26
Regenerative cooling nozzle. Brian Fidelity CFD 3 September 1, 2005 08:53
3 bodies in 1 part Atit CFX 7 October 22, 2004 14:41
Regenerative cooling rocket engine Brian Main CFD Forum 0 November 12, 2003 06:59
Regenerative cooling nozzle. Brian Main CFD Forum 0 November 10, 2003 01:11
