[Other] Why 'Failed to Concatenate Edges' Fault? (Spaceclaim) |
February 26, 2024, 03:47 |
Rep Power: 2 |
(Repairing geometry in Ansys Spaceclaim) Is there anyone here that could help me understand the 'Failed to Concatenate Edges' fault message. I have two faults remaining after using the 'Split Edges' repair tool. Is there a simple workaround to resolve this or does the geometry have to be recreated from scratch? Thanks, Martin |
June 10, 2024, 23:31 |
The Split Edges fix tool's "Failed to Concatenate Edges" message means that there was a problem with how the tool was able to join (or merge) the split edges back together.
gorilla tag Last edited by kundewayne; June 11, 2024 at 21:16. |
failed, repair geometry, repair surface, spaceclaim |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
[ANSYS Meshing] Extra edges error in Spaceclaim | Simranjeet Kaur | ANSYS Meshing & Geometry | 0 | July 17, 2021 09:29 |
addr2line failed error and Segmentation fault error | shivamswarnakar72 | OpenFOAM | 1 | July 5, 2020 06:02 |
Transient boundary conditions | Jarrod Sinclair (Sinclair) | OpenFOAM Running, Solving & CFD | 133 | May 6, 2015 06:21 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
