[ANSYS Meshing] One or more entities failed to mesh. The mesh of the bodies containing these entities
Old   February 26, 2024, 12:37
Default One or more entities failed to mesh. The mesh of the bodies containing these entities
Emmanuel Quayson-Sackey
Quayson-Sackey is on a distinguished road
I am trying to mesh a 3D wind turbine blade in ANSYS MESHING.
I created the 3D wind turbine blade with twist by using the rotation command at the aerodynamic center of the airfoil .
I also created a C type domain around the blade and extracted the blade using the Boolean technique.
I keep getting this error whenever i mesh the domain .
Whenever to see show the problem, it indicates red on the edge of the geometry. I have changed the blade dimensions but to no avail. I am using 2 sections of NACA 64-618 at the very tip of a NREL 5MW wind turbine.
Quayson-Sackey is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
[ANSYS Meshing] One or more entities failed to mesh. bjkozn ANSYS Meshing & Geometry 2 October 24, 2018 07:22
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 sam.ho OpenFOAM Installation 35 April 5, 2014 15:31
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
