[ANSYS Meshing] One or more entities failed to mesh. The mesh of the bodies containing these entities |
February 26, 2024, 12:37 |
Emmanuel Quayson-Sackey
I am trying to mesh a 3D wind turbine blade in ANSYS MESHING.
I created the 3D wind turbine blade with twist by using the rotation command at the aerodynamic center of the airfoil . I also created a C type domain around the blade and extracted the blade using the Boolean technique. I keep getting this error whenever i mesh the domain . Whenever to see show the problem, it indicates red on the edge of the geometry. I have changed the blade dimensions but to no avail. I am using 2 sections of NACA 64-618 at the very tip of a NREL 5MW wind turbine. |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
[ANSYS Meshing] One or more entities failed to mesh. | bjkozn | ANSYS Meshing & Geometry | 2 | October 24, 2018 07:22 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 15:31 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
