Blocking strategy
Old   July 12, 2009, 15:33
Default Blocking strategy
Michal
Twix is on a distinguished road
Hi
What will be the best blocking strategy ( 2D only for fluid around the blade) for this geometry.
Thanks in advance.
Twix is offline   Reply With Quote
Old   July 13, 2009, 20:59
Default Example...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Try something like this...
Basically, you use quarter ogrids on each end to shift the flow and give you more mesh where you need it, but things hook up periodic in the end...
You can do lots of similar things (I always start with a pen and paper). You could add more quarter ogrids to off set it more, or you could do an lgrid which puts more mesh out the back...
I am interested in what other good layouts our clever colleagues and post here.
PSYMN is offline   Reply With Quote
Old   July 14, 2009, 18:46
Michal
thanks for quick reply. I made this blocking but I have another question. When I change edge parameter on one edge it influent to other edges and I can’t set proper number of nodes. Why?
Old   July 15, 2009, 08:46
Michal
Hi, it’s me again I know why those edges was dependent and I couldn’t set proper number of nodes. I don’t delete block permanently.
Regards
Old   July 15, 2009, 09:47
Default Have Fun.
PSYMN's Avatar
Simon Pereira
Yea, if you don't delete that inner block permanently, things will propagate across...
Have fun.
Old   July 15, 2009, 09:49
Default Tip Gaps
PSYMN's Avatar
Simon Pereira
On the other hand, if you need to model the tip gap, you will need to use a blocking straegy that does not rely on deleting that inner block. The quarter ogrid trick I showed can be slightly modified to work without deleting your inner block.
Old   July 15, 2009, 18:26
Michal
Hi I have another problem, I don’t know how to fix penetrating elements. For mesh consist of 600 000 elements I have about 5000 penetrating elements on boundary fluid-solid . I think that is the reason why I can’t decrease y+ below 1.
Thanks in advance
Old   July 16, 2009, 13:50
Default scan planes to the rescue
PSYMN's Avatar
Simon Pereira
This could be due to a bunch of things, most likely projection (association) issues. View some cross sections (scan planes) across the area where the penetration is happening and try to figure out what is not projecting correctly...
Old   July 19, 2009, 16:18
Michal
Hi.
You was right Simon it was association problem, I don’t associate some curves. Now I don’t have penetrating elements and y+ is bellow 1.
Thank You very much.
Regards
Old   June 25, 2010, 17:55
Saima
Saima is an unknown quantity at this point
Do you guys please let me know how you creat this outer boundary of blade is there any rule? if yes pls let me know?
Secondly how u did meshing in ICEM CFD i did tutorial which is available on you tube but still i am not getting how i can do for blade?
If you have some documentation on it pls send me on samahmedpk2000@hotmail.com
Thank you and Regards,
Saima is offline   Reply With Quote
Old   June 27, 2010, 13:07
Default 2D NASA Rotor 67 Blade prifile blocking
  #11
t_shirt
t_shirt is on a distinguished road
Could ypu please let me know how can i creat blocking for this profile?
Pic is atatched here.
t_shirt is offline   Reply With Quote
Old   June 28, 2010, 12:09
Michal
Watch this tutorial, it should help.
http://www.youtube.com/watch?v=tYrbS...eature=related
Regards
[ICEM] Blocking Strategy hubidoo ANSYS Meshing & Geometry 9 June 5, 2009 10:56
Strategy for keeping track of files and folders? Dre CFX 1 October 30, 2008 13:00
ICEM blocking Chris Wetton CFX 6 March 9, 2008 05:18
Mesh is created in blocking Severin CFX 3 September 18, 2007 09:02
Poinsot and Lele Characteristic BCS strategy for NS equations Ravikanth Avancha Main CFD Forum 1 March 15, 1999 19:51
