[GAMBIT] Asymmetric boundary layer (3D) on surface of a half sphere
Old   September 22, 2009, 14:16
Question Asymmetric boundary layer (3D) on surface of a half sphere
Jochen Halfmann
Jochen Halfmann is on a distinguished road
Hi Folks,
I created a sphere geometry inside a brick. Then I split both volumes and surrounded the sphere with a sizing function (shaped like a mach-cone). After that i applied a BL on the sphere surface and meshed both volumes. So far everything worked fine.
To reduce the amount of mesh-volumes i decided to use just one half of that geometry. I removed all meshes and BLs and cut it in half.
Now when i try to attach the BL onto the surface of the half sphere it generates the BL but at one spot its becoming thinner and later its growing back to normal thinkness again. I used the Uniform sheme for the BL. Does anybody have an idea why this asymmetry results and/or how to remove it?
Thanks in advance,
Jochen
Jochen Halfmann is offline   Reply With Quote
boundary layer, gambit, problem, sphere, surface
gambit boundary layer meshing Rick FLUENT 7 May 5, 2016 13:29
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
Errors in Gambit for boundary layer mesh Mike Spears FLUENT 0 June 23, 2005 11:34
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
channel half width/ boundary layer thickness Peter liang Main CFD Forum 3 September 27, 2001 04:10
