[GAMBIT] Import drawing file
Old   September 26, 2009, 11:41
Question Import drawing file
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi there!!!
I just wanna make banki water turbine by using FLUENT. But i cannot draw it in GAMBIT easily. I read some option in GAMBIT there are some option to import and export file.
My question is HOW TO IMPORT DRAWING FILE FROM ANSYS CFX TO GAMBIT??
i have heard that the drawing in ANSYS CFX is easier than GAMBIT.
Thanks For your attention!!!
teguhtf
teguhtf is offline   Reply With Quote
Old   September 28, 2009, 02:27
-mAx-'s Avatar
Maxime Perelli
drawing from cad soft will be easier...
Old   September 28, 2009, 02:38
Question What kind of CAD SOFT??
teguhtf's Avatar
teguh hady
what kind of cad soft?? is that autoCAD or what?? and what version will be compatible with GAMBIT 2.2.30??
Old   September 28, 2009, 03:44
-mAx-'s Avatar
Maxime Perelli
autocad, proe, catia, solidworks, etc...
you don't need any compability with cad software, because you will just import an step / iges file
Old   September 30, 2009, 16:51
Post
teguhtf's Avatar
teguh hady
I'm sorry. I've tried but it doesnt work. Could you tell me the detail step?? Plz
Just for example in AUTOCAD to GAMBIT or On the contrary...
Thx B4
Teguhtf
Old   October 1, 2009, 01:39
-mAx-'s Avatar
Maxime Perelli
check in autocad if there is the possibility to export in iges or step file
Old   October 12, 2009, 11:10
Question
teguhtf's Avatar
teguh hady
Hi!!!
I've tried much step to convert GAMBIT to autoCAD or on the contrary!!
But it cannot works. Then i use ICEM CFD as mediator to convert it and it works only autoCAD to ICEM CFD & FLUENT mesh to ICEM CFD.
I dont know where is my wrongness steps.
Could you show me??
Thanks a lot???
teguhtf
Old   October 12, 2009, 15:01
Default Just export the geometry.
PSYMN's Avatar
Simon Pereira
I can't make sense of your post to understand how you are involving ICEM CFD in this but it doesn't matter.
All you need is the model in some CAD tool or where ever you drew it... Then find the option to Export or Export Geometry or something like that (usually under "File" in the top menu bar). If you did it in DesignModeler, you can export it from there too...
Export it in an IGES, STEP, ACIS, Parasolid or what ever format you can... Then go over to Gambit and read it in...
If you are already in CFX, why not finish the job there?
Old   October 12, 2009, 23:09
Post
teguhtf's Avatar
teguh hady
I'm sorry if my step is complicated. Well, In this project i use GAMBIT 2.3.30 & FLUENT 6.2.16. I choose them because it needs less computer power than others. But the problem of this software is difficult drawing. i have tried to export and import by using "export and import" option on File in menu bar. but it doesn't work. i use other software to solve my problem.
I hear that ANSYS 11 (especially ICEM CFD) can be collaborated with AUTOCAD. hence, i think i can work on GAMBIT too. And then i use ICEM CFD as mediator to convert my geometry from "AUTOCAD to GAMBIT" Or "GAMBIT to AUTOCAD".
I'm sorry if this is basic question!!!
Thank you very much for your attention!!!
teguhtf
Old   October 12, 2009, 23:19
Default Fewer steps is better.
PSYMN's Avatar
Simon Pereira
So you have the model drawn in autocad and then you save it as a DWG or DXF file, read that into ICEM CFD and then export that as an IGES file for reading into Gambit...
Instead, just File => Export (or what ever it takes in AutoCAD) to output an acis (SAT), Step or IGES file (in that order of preference) and then read it directly into Gambit and go from there.
ICEM CFD is not helping, it is just another step that further corrupts your data.
Old   October 13, 2009, 01:33
Smile
  #11
teguhtf's Avatar
teguh hady
Thanks, Hope It works!!!
Old   October 16, 2013, 10:09
hossein
hzeidabadi is on a distinguished road
hi dear friend
banki turbine have a simple geometry and i offer you to use gambit....
hzeidabadi is offline   Reply With Quote
cfx, drawing, gambit, import
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
Import data from another .cas file of fluent Umesh FLUENT 1 August 17, 2003 04:51
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
