[ICEM] Please help a mesh problem
Old   October 6, 2009, 17:32
Default Please help a mesh problem
zhaohui is on a distinguished road
I used ICEM to creat a mesh for a gas filter. Basically it has lots of pipe-in-pipe structures and it costs me, a new user of ICEM, long time to creat a hex mesh.
But when I output the mesh to fluent, fluent indicates it has an error. The warning message is "no face for a node, centeroid xc=-0.54,yc=-0.59,zc=-0.54".
Anyone know what causes this problem? How should I correct it?
Thanks a lot!
Zhaohui
zhaohui is offline   Reply With Quote
Old   October 7, 2009, 07:39
Ryne Whitehill
rwryne is on a distinguished road
Try this:
Under the Edit Mesh tab, click the "Check Mesh" option (shows a grid with a check mark)
Run that with its default settings before exporting your mesh and see if htat fixes your problem.
rwryne is offline   Reply With Quote
Old   October 7, 2009, 10:38
Default Uncovered faces...
PSYMN's Avatar
Simon Pereira
Fluent requires that the volumes be surrounded by shells so it can hang bocos on them. (CFX can close them off for you).
My guess is that you have some "uncovered faces" somewhere. There is a check for this under the Edit Mesh => Check Mesh.
To fix it at the blocking level, find the face and associate it with the adjacent surface.
Old   October 7, 2009, 16:33
Thank you so much, Ryne!
Zhaohui
Old   October 7, 2009, 16:34
Thank you so much, Simon and Ryne! I will try your suggestions right now.
Thanks again!
Zhaohui
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
[GAMBIT] Problem with mesh. Please Help... maziboss ANSYS Meshing & Geometry 1 September 28, 2009 02:24
mesh generation problem Ellen FLUENT 7 February 18, 2009 21:20
mesh control problem TUM CFX 4 July 27, 2001 16:17
Convergence problem when ustructured mesh is used. SangJin Ryu Siemens 3 October 5, 2000 20:26
