[GAMBIT] help( solid and liquid mixing)
Old   October 14, 2009, 01:38
Unhappy help( solid and liquid mixing)
sanaz
sanaz is on a distinguished road
Hi, I am simulating the liquid-solid flow using FLUENTin in stirred tanks using impeller. My problem is that when I go to the multiphase model, it does not read the solid material and how to build geometry (for soild) in gambit? how to define solid material for gambit. How can I make it reads the solid phase in the multiphase model? Thanking you for any help regarding this problem.
sanaz is offline   Reply With Quote
Old   October 14, 2009, 02:04
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
do you have to construct your geometry within gambit, or do you have to import a cad file?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 14, 2009, 02:18
sanaz
yes. I have to construct my geometry within gambit.
Old   October 14, 2009, 02:22
sanaz
Yes. I have to construct my geometry within gambit.My problem is more for solid.
Old   October 14, 2009, 02:26
-mAx-'s Avatar
Maxime Perelli
Do you have the possibilty to construct your geometry with a cad software? Because building an impeller with gambit won't be easy
Old   October 14, 2009, 02:29
Default structure
sanaz
This is link for structure of bulid in gambit
http://rapidshare.com/files/292770298/rush.JPG.html
Old   October 15, 2009, 10:25
-mAx-'s Avatar
Maxime Perelli
sounds like ok, take care to model the fluid domain and not the solid one.
Solid particles for multiphase is embeded in Fluent (check user guide), but you don't have to model and mesh them (hopefully...)
help( solid and liquid mixing) sanaz Main CFD Forum 1 October 21, 2009 01:41
solid liquid phase change (melting/solidification) ernane CFX 0 February 3, 2009 14:24
Heat transfer from solid to liquid Richard FLUENT 2 January 30, 2006 04:10
Shacking CAN VOF HEAT LIQUID SOLID Optixxx FLUENT 0 July 30, 2005 11:42
solid suspension in moving liquid Jason FLUENT 4 October 27, 2003 18:59
