[ICEM] 2D All Tri mesh, problem when reading into Fluent
Old   May 11, 2011, 10:01
Default 2D All Tri mesh, problem when reading into Fluent
Henrik Hed
gogga is on a distinguished road
Hello all!
I have a 2D geometry which I have meshed with the "All Tri" and "Patch independent" method. The quality of the mesh is good.
The problem occurs when I try to read it into Fluent. I get two different errors depending on which mesh I have been using(I've tried like 20 different...).
1. Null pointer
2. Fatal signal violation
I have read some threads where PSYMN indicates that the problem often is the element lines around the perimeter.
If I turn all geometry off and turn Mesh - lines on, I will se my geometry.
One line seems to have a hole in it. Is this just the graphic or is it the problem?
How can I fix it?
Please help me in the right direction!
Thanks,
Henrik
gogga is offline   Reply With Quote
Old   May 16, 2011, 03:35
Henrik Hed
Adding information:
The poblem can be described as a 1/4 of a circle with thin layers along the bended curve.
I have not longer the problem with the hole in the line mesh, but I have still the problem when reading it into FLUENT. ("Fatal signal (SEGMENTATION VIOLATION)").
It would be very helpful if I could get some hints on what to do!
/Henrik
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 03:02
Problem with 2D ICEM mesh check in fluent Nicola FLUENT 3 March 25, 2013 05:56
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
