[ICEM] Create part in region ... defined in cylindrical coordinates
Old   February 24, 2010, 08:20
Default Create part in region ... defined in cylindrical coordinates
prout
zboud is on a distinguished road
Hi all,
I'd like to create a part in a region defined in cylindrical coordinates, let's say:
Min R = 0
Min theta = 0
Min z = 0
Max R = 360
Max theta = 2*pi
Max z = 200
Is it possible to define such a part in ICEM, and if so, how can I do it?
Thanks.
zboud is offline   Reply With Quote
Old   February 24, 2010, 08:34
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
You can create a cylindrical geometry as you defined. But do you mean to generate a cylinder?
rikio is offline   Reply With Quote
Old   February 24, 2010, 08:49
prout
Sorry I was not precise enough.
My mesh is already defined, my geometry is created. What I want is to define a region of the mesh(using cylindrical coordinates), put all the elements from that region in a part, so I can use it to define boundary conditions in CFX.
I might have found something though: a loop in my script scanning the concerned cylindrical region and adding the elements to a subset which could be used to create a part. But that's quite heavy for such an easy concept!
Old   February 24, 2010, 09:05
Rikio
Have you tried to create a cylindrical coordinate in CFX, and set the BC?
Maybe I misunderstood your idea: meshes on cylindrical surface would be in the surface part, no need to select manually, or by loop script.
Old   February 24, 2010, 09:15
prout
I need a mesh region to define the BC in CFX...
The thing is I have many surfaces, so I can't just select the surface meshes.
And the other thing is that everything has to be automatic in a script, because many similar geometries will be tested.
But the selection script should be quite simple once the bounding boxes are defined.
EDIT: here's the script I wrote in case anyone is interested.
for {set i 0} {$i<$nblayers} {incr i} {\
mess "Ajout de la zone $i...";\
set alpha [expr {$layerangle*2.0*$pi/360.0}];\
set xmin [expr {-($R*(1.0-cos(($i+1.0)*$alpha)))-0.5*$firstR*cos($i*$alpha)}];\
set ymin [expr {$R*sin($i*$alpha)-0.5*$firstR*sin(($i+1.0)*$alpha)}];\
set xmax [expr {-($R*(1.0-cos($i*$alpha)))+0.5*$firstR*cos($i*$alpha)}];\
set ymax [expr {$R*sin(($i+1.0)*$alpha)+0.5*$firstR*sin(($i+1.0)* $alpha)}];\
set zmax [expr {$L*1.5}];\
mess "xmin: $xmin\n";\
mess "xmax: $xmax\n";\
mess "ymin: $ymin\n";\
mess "ymax: $ymax\n";\
mess "zmax: $zmax\n";\
ic_uns_subset_add_region uns_sel_0 "\
$xmin \
$ymin \
-10000" "\
$xmax \
$ymax \
$zmax\
" 0 {1 2 3};\
mess "Zone $i ok!\n";\
CFX and cylindrical coordinates VSB CFX 16 December 10, 2019 08:53
cylindrical or rectangular coordinates Maldoror ANSYS Meshing & Geometry 0 October 10, 2009 21:09
How to create an user defined function? Cagdas FLUENT 1 September 5, 2007 20:02
Cylindrical obstacles in cartesion coordinates Brajesh Tripathi Phoenics 4 July 16, 2007 00:23
