[ICEM] How can I set the edge parameters so that they override the part mesh setup?
Prev Previous Post   Next Post Next
Old   April 13, 2010, 18:28
Default How can I set the edge parameters so that they override the part mesh setup?
Joshua Counsil
Josh is on a distinguished road
Hi all -
I've managed to create a structured mesh over a blade-to-blade turbine cascade region, shown below. However, I cannot seem to specify the domain as two-dimensional. I use Blocking > Pre-Mesh Params > Edge Params and specify the z-directional edges as two nodes in width (for two-dimensionality).
However, even when I do, I end up with three nodes, as shown in the second picture.
I know this is because the Mesh > Part Mesh Setup is interfering with the results for the following reason. Right now, my max size for all the parameters is 5 mm. However, when I change it to 10 mm, the z-directional edges have only two nodes, like I specified!
I know I could avoid using the Part Mesh Setup, but I need it as I want an inflated boundary layer on the turbine blades.
Is there anyway to use both and still have a two-node (i.e. two-dimensional) thickness?
Josh is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
Structured mesh of a 3d sharp trailing edge Gilles Main CFD Forum 2 May 23, 2008 13:23
Set a set of circular initial conditions on a mesh jinwon park Main CFD Forum 0 January 26, 2008 11:10
