[ICEM] Two liquids flowing counter current in concentric tube
Old   April 26, 2010, 01:35
Default Two liquids flowing counter current in concentric tube
Sujay
sujay is on a distinguished road
Two liquids are flowing counter current to each other in tube without mixing. one liquid (liquid 1)enters from top in inner tube and leave from bottom at 1500 0 C Other (liquid 2)enters at bottom in outer tube and leave at 30 0 C. Both these liquid have differnt properties and doeas not mix.
How to create geometry in ICEM and Solve in CFX? the concentric tube is made up of copper.
sujay is offline   Reply With Quote
Old   April 26, 2010, 08:30
Default Easy...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
That is a very open question... But it will be pretty easy.
Tetra or Hexa, you just need material points for each of the regions. You didn't mention if you would have a solid region between the materials, but I will assume you will.
If you go with Tetra, flood fill (part of the regular process) will automatically assign the volume elements to the right materials based on the material point locations. You will also want to grow prisms into each of the fluid regions.
If it is Hexa, you would use an Ogrid with its center H grid well within the inner pipe, then split the Ogrid for each of the layers and assign the blocks to the different materials.
When you output the mesh, tell your solver which materials are fluid and which are solid and it shouldn't have any problems.
PSYMN is offline   Reply With Quote
Old   April 26, 2010, 08:49
Sujay
Please tell me more. I want to go with tertra mesh. The tubes are made up of Copper. But how to say two differnt liquids in CFX.
Old   April 26, 2010, 23:50
Sujay
Do i need to create two solid domain (tube) and two fluid region ? four material point ?
Old   April 28, 2010, 02:57
Sujay
Ok, I am able to make the geometry having four doamain. Will it take the values at each interface on it's own or we have to speicify the interface conditions.
Old   April 28, 2010, 10:55
Default Solver question...
PSYMN's Avatar
Simon Pereira
The amount of work required to setup the solid/fluid interfaces varies from solver to solver. It is pretty automatic in more modern commercial solvers like "ANSYS Fluent" or "ANSYS CFD".
If you mesh it all at once in ICEM CFD, you will have node for node connected meshes with a layer of shells (quads or tris) between the volumes. I would probably just make sure that the surface part between each pair of volumes has its own name (such as INTERFACE_COPPER_FLUID1) and your solver can probably figure out the rest.
You can confirm on your solvers forum or just try it and see.
Simon
Concentric Tube Heat Exchanger Analysis Abhishek CFX 3 November 8, 2011 05:45
Inclination angle and counter current flow Prabha FLUENT 3 April 11, 2011 21:00
Two liquids flowing counter current in concentric tube sujay ANSYS 0 April 26, 2010 01:01
Modelling a gaz-liquid counter current flow? Arou FLUENT 0 March 9, 2008 06:12
concentric tube heat exchanger satya CFX 4 January 16, 2002 09:06
