Meshing doubt
Old   May 3, 2010, 09:12
Default Meshing doubt
Arjit Arora
arjit is on a distinguished road
Hi guys!
Can I get accurate results of CFD of a 3D wing (finite) if I dont use a boundary layer, but instead, a very fine unstructured mesh near the boundary.. growing towards the exterior?
Thanks!
arjit is offline   Reply With Quote
Old   May 3, 2010, 09:17
Default contd..
Arjit Arora
One of the tutorials that I found online was this:
[http://hmf.enseeiht.fr/travaux/CD010...nual/index.htm
Do you think I can get accurate results with such a setup?
Old   May 3, 2010, 11:22
Ming
h.m lee is on a distinguished road
depends your turbulence model.
h.m lee is offline   Reply With Quote
Old   May 3, 2010, 18:33
Chris
Chris D is on a distinguished road
If you use an unstructured mesh, you'll need more gridpoints to resolve the boundary layer than you would need if you used structured. This is because hexes can tolerate more stretching than tets. Just out of curiosity, why do you want to use unstructured instead of structured?
Chris D is offline   Reply With Quote
Old   May 4, 2010, 04:22
Default Re:
Arjit Arora
Thanks for the reply Chris!
I had initially gone in for a structured BL with a structured mesh.
However, for the geometry that I am currently meshing, structured meshing doesn't seem to be appropriate, I have to use unstructured mesh.
Is a structured BL compatible with an unstructured mesh?
If so, how?
Thanks again!
Old   June 8, 2010, 20:15
Default Tetra Prism.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If your geometry is complicated and you would rather go with tetras than hexas, that is fine, but you should insert inflation layers (prism layers) to capture the viscous boundary layer. You could do it with just tetras, but you would need so many that it wouldn't be practical. prisms allow you to have the higher number of elements perpendicular to the wall, and growing in a way that efficiently captures the velocity profile, but without increasing the node count isotropically...
A tetra prism mesh is considered standard these days and is a fully unstructured mesh.
PSYMN is offline   Reply With Quote
Old   June 9, 2010, 11:16
Ming
If so, how?
Thanks again!
Yes, Prism is prepare specially for BL.
And maybe you mean you want to use hybrid mesh. You can use Hexa-8 in BL, that likes structured mesh. Its efficient is more than 2 times than Penta-6( Prism). And Tetra-4 in far field.
3d wing, boundary layer, structured, unstructured
Doubt regarding 3-D meshing of a rocket nose nakul OpenFOAM Pre-Processing 0 April 3, 2010 15:54
doubt in meshing: physics jai Main CFD Forum 0 May 9, 2009 07:17
doubt on meshing joe FLUENT 2 September 12, 2005 13:17
doubt on meshing a cylinder FELIX JOE S FLUENT 13 July 27, 2005 08:06
ProAm meshing...Doubt Antony Siemens 5 July 26, 2004 05:31
