[GAMBIT] How to convert a 2D pipe geometry to 3D?
Like Tree1Likes
  • 1 Post By -mAx-
Old   June 16, 2010, 12:42
Default How to convert a 2D pipe geometry to 3D?
A Suhaila
Anis is on a distinguished road
I have a 2D geometry in Gambit (axial and radial ie. x,y)and need to convert it to 3D by adding another coordinate. Please advise.
Thanks
Anis is offline   Reply With Quote
Old   June 17, 2010, 01:47
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Basically you can use Sweep Faces for extrusion, or Revolve Faces for revolution.
Or you can also try this: (sweep Faces with path)
behzadmaha likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 2, 2010, 06:07
A Suhaila
Thanks Maxx, I have revolved the faces and edges. Actually, I'm not having a smooth straight pipe but it has a constriction (vena contracta). I got the 3D geometry by revolving but Gambit was not reading it as a volume. Once i convert it to volume , then i can start meshing. The thing is, how make it as volume? I look at 3D meshing tutorials, it all start with creating volume.
Old   July 2, 2010, 07:05
-mAx-'s Avatar
Maxime Perelli
*either you do your revolving with Volume/Revolve (from a face)
*or yo keep what you did, and you create your volume with stitch face (you will need to close your volume, by creating some faces --> enable shaded mode on, it will help you to see which face you need to create)
Old   July 2, 2010, 08:29
A Suhaila
Max, do you know what this error means?
ERROR: Cannot create ACIS BODY. Is this an open shell?
Old   July 2, 2010, 09:56
-mAx-'s Avatar
Maxime Perelli
The error means what I mentionned earlier: you need some faces to close the volume.
enable shaded mode on, you will see where you need to close your volume
Old   July 2, 2010, 10:32
A Suhaila
got it!! ready to mesh. Thank you , Max
Old   May 23, 2012, 02:55
vibhor goel
vibhs is on a distinguished road
I still didnt get it...can you guys help me out...actually i am trying to stich the circular faces of two cylinders...and make 1 cylinder out of them...
vibhs is offline   Reply With Quote
Old   May 23, 2012, 07:34
-mAx-'s Avatar
Maxime Perelli
enable shaded mode on. Maybe you will see any missed surfaces.
Old   May 23, 2012, 07:38
vibhor goel
I got that...Thnx Max for ur reply...
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 08:24
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
